Bronze
Can I monitor Lines on 7914
Can I setup monitor lines on 7914 meaning that the monitor lines will flash but will not pop up with info on the main 7960/61 phone
1 REPLY
Super Bronze
Re: Can I monitor Lines on 7914
If you have CME yes - just add the same lines as the phone you wish to monitor to the 7914 with m instead of :, i.e. 7m1 8m5 etc...
If you are on CM, then it doesn't work as well - you can't do Direct Station Select for transfers/calls etc.
In CM you could add the lines as shared lines, but the caller info appears still...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
115
