Can not enter a location ID Because of Unity Bridge not installed
We can not add Location ID's because Unity is licenced for Bridge but it will not be installed. When Trying to save location ID, prompted to enter Unity bridge ID.
Version 3.1.5
1 REPLY
Re: Can not enter a location ID Because of Unity Bridge not inst
Yes, no problem there. It will ask you to enter a server address for the Bridge server as well, which you can also enter a 'dummy' address for now. As long as you make sure to set these to the correct values before you actually install the Bridge you should be just fine.
Also note that you may have problems saving changes to this primary location object if the schema has not been extended for the Bridge. If you haven't run the Bridge schema extensions already (just an additional option in AdSchemaSetup.exe) I'd go ahead and do that now.
Hope that helps.
116
