Community Member
Can not forward calls
Folks,
Brand new installation of CCM 4.1(3) SR6, we are unsbale to forward calls to external or internal numbers using the phone (softkey forwardall). it says "database error" on the phone when we try to do it?? any ideas??
However if we make the change on the callmanager administration page it takes it and lets us forward calls.
Hall of Fame Super Red
Re: Can not forward calls
Hi Navin,
Sounds like a replication problem. Is the phone registered to a subscriber? If so the SQL Subscription may be broken. Have a look at these docs;
Cisco CallManager Issues with Call Forward All
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801b3f4b.shtml
Reestablishing a Broken CallManager Cluster SQL Subscription with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
Hope this helps!
Rob
Please remember to rate helpful posts.......
Please wait five seconds after you press the CFwdALL softkey before you enter the number.
Let me know if you experience the problem with that.
//J
Also restarting the DataBaseLayerMonitor service is a good workaround while having issues with the CallForward.
Community Member
Call forward to PSTN |mobile| showing "High Traffic Try Again Later"!
710
