12-02-2005 07:11 PM - edited 03-13-2019 11:25 AM
I just setted up a CCME environment for a customer office.
All the ip phone functions seems normal,except I can not transfer a call from pstn to the internal user.(assume I'm a receptionist,can not transfer incoming call to other extention)
But the call transfer between the internal phones is ok.
The CCME version is 3.2,ios version is "c2800nm-ipvoice-mz.123-11.T8.bin"
The VG has 8 FXO ports for the PSTN connections.
Solved! Go to Solution.
12-02-2005 10:54 PM
Hi Lane,
Check this very good reference:
transfer-system {blind | full-blind | full-consult | local-consult}
transfer-pattern transfer-pattern [blind]
Gonz
12-02-2005 10:54 PM
Hi Lane,
Gonz
12-03-2005 12:50 AM
Hi Gonz,
Yes,I have tried transfer-system full-blind & blind.
In condition of transfer-system blind,the pstn call can not be transfered.
In condition of transfer-system full-blind,the pstn call transfer can make the desti-extention ringing.But when I pickup the phone,I can hear nothing.It seems that the call can not be established properly.
Thanks for your reminder.I will try other parameters next monday.
12-03-2005 08:05 AM
Are youre ephones setup for dual-line. If not,then you cannot do any consultative transfere.
12-04-2005 07:58 PM
The call transfer function in Full_Consult mode works well.So,this problem is not urgent any more.
But I still feel strange that why blind transfer can not work in this system.Does the incoming caller-id affect this function?
Anyway,thanks you 2's great help.
12-05-2005 11:41 AM
I am having intermittent problems at a client site with blind transfer, specifically with incoming calls that are caller-id blocked. Is anyone having this problem as well?
