Community Member
Can two PBXs with PRI interfaces use VOIP?
I have two Magic PBXs with PRI interfaces. Can I use VOIP to
connect the 2 systems? If so,
what router and interfaces are
required?
1 REPLY
Anonymous
N/A
Re: Can two PBXs with PRI interfaces use VOIP?
Yes thats the whole idea of VoIP.
you need a voice gateway say 26xx,364XX ,as5300, c7206VXR,mc3810
with voice PRI Network module, PA's or 5300 with
vfc cards and T1/E1 interfaces.
The pbx pri interface can be connected to the router
PRI interface and ip between the two routers.
here are some useful information
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120xk/1205xk/t1_vo_xk.htm
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7505/portadpt/voice_pa/pa_t1_e1/6229conf.htm
a minimum of 12.1(5)T8 ip plus should be used.
88
