Cannot create pri-group on 2801 with VWIC-1MFT-T1 + (2) PVDM-8
So I have a 2801 with:
A) (1) VWIC-1MFT-T1 for PRI interface to PBX (SLOT 0)
B) (2) PVDM-8 DSP cards (1 came with the router, one added + recognized)
C) (1) WIC-1DSU-T1-V2 for data T1 interface (SLOT 2)
This is a little easier:
NAME: "C2801 Motherboard with 2 Fast Ethernet", DESCR: "C2801 Motherboard with 2 Fast Ethernet"
PID: C2801 Motherboard with 2 Fast Ethernet, VID: 4.1, SN: FTX0907Y0TG
NAME: "WIC/VIC 0", DESCR: "One port T1 voice interface daughtercard"
PID: One port T1 voice interface daughtercard, VID: 1.0, SN: 27253652
NAME: "WIC/VIC 2", DESCR: "WAN Interface Card - DSU/CSU T1 Fractional (V2)"
PID: WAN Interface Card - DSU/CSU T1 Fractional (V2), VID: 1.0, SN: 4294967295
NAME: "WIC/VIC 4", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
PID: PVDMII DSP SIMM with one DSP with half channel capcity, VID: 4.1, SN: 0
NAME: "WIC/VIC 5", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
When I attempt to create the pri-group I get:
controller T1 0/0/0
framing esf
clock source internal
linecode b8zs
cablelength short 133
(config)#controller T1 0/0/0
(config-controller)#pri-group timeslots 1-10,24
%Insufficient resources to create pri-group - it has been removed
(config-controller)#pri-group timeslots 1-5
(config-controller)#pri-group timeslots 1-2
(config-controller)#pri-group timeslots 1-2,24
Anyone know if I have to have 24 DSPs to create a PRI group with even only 10 channels used? Should I try it with the VWIC in another slot?
Re: Cannot create pri-group on 2801 with VWIC-1MFT-T1 + (2) PVDM
I think your issue may be you need to issue the network-clock-participate wic 0 command for that interface. I think after you do that it will clear up the issue.
Silver
Hmm - this is not encouraging, may be your problem- from the 2800 Hardware Install guide:
Note Slot 0 does not support PRI on T1/E1 VWICs, only channel-associated signaling (CAS) digital voice.
http://www.cisco.com/en/US/partner/products/ps5854/products_installation_guide_chapter09186a00802c5af1.html
Mary Beth
Good catch! Mary.
But i have a multiflex t1 in slot 0 doing pri now in a 2821.
Strange
Thats a restriction only for the 2801.
Silver
Yes, I should have been more clear - that comment was buried at the end of the 2801 section.
Mary Beth
965
