Cannot mke offnet calls with Video Advantage running
jidesai01
I have Video Advantage version 2.1.2. When I make an offnet call via an h323 gateway, I hear a fast busy and the called person hear the phone ring. When they answer the phone, they get dead air. When I close or disable Video Advantage, I have not problems with calls.
Jaime Valencia
When running Video Telephony Advantage (VTA), outbound calls fail from Cisco CallManager through H.323 gateways to PSTN. An invalid bearer capability IE field is indicated in the release_comp message
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K18460760
java
if this helps, please rate
java
Jaime Valencia
java
java
This seems to have done it. Thanks!
