10-03-2003 10:35 AM - edited 03-13-2019 01:54 AM
Im deploying a new callmanager 3.3(3) cluster.
When I try to use the CDR reporting and analysis tool I get the following error
30025 Data is available only upto Oct. 2, 2003
I have the CDR flags enabled in service parameters
Has anyone else run into this
10-03-2003 10:45 AM
Make sure the CDR enabled flag is set to true on all CCMs across the cluster, and also ensure that the CDR insert service is running on the publisher.
10-03-2003 11:15 AM
They are and the CDR services are running
10-03-2003 11:52 AM
If this is the case, then the only explanation is that CAR is possibly unable to load all the CDRs. I came across a similar problem when the system date was inadvertantly changed on a CallManager to another year.
After the date was changed back, the CDRs had to be reloaded again. Doing this forces CAR/ART to get all the CDR data in the database when it next loads the data.
Doing this would delete all the previoulsy loaded records and will load all the CDR records available from the CDR database into CAR/ART database afresh.
10-03-2003 12:09 PM
How do you initiate a reload of the CDR records?
10-03-2003 12:27 PM
The process is unfortunately not straight forward, and may not resolve your particular problem:
1) Go to Programs -> SQL Server -> Ent Mgr SQL Server -> SQL server Group -
choose the CM server. Choose ART database.
2) Delete all the records in the following table. To delete the records,
select the table, open it and choose Delete on the SQL menu and then run the command.
delete from Tbl_Load_History
delete from Tbl_Dump_PkID
delete from Tbl_Error_Id_Map
delete from Tbl_Billing_Data
delete from Tbl_Billing_Error
delete from Tbl_Dump_CallDetailRecord
delete from Tbl_Dump_CallDetailRecordDiagnostic
3) This will force ART to get all the CDR data in the database when it next loads data. As previously mentioned, doing this would delete all the previously loaded records and will load all
the CDR records available from the CDR database into ART database afresh with the new settings(charge, dialplan, etc.)
Note that auto generated reports that already exist will not have the newly loaded records.
10-03-2003 12:32 PM
Thanks, Will I have to do this every time I need to run reports?
10-03-2003 12:49 PM
No, this should not be the case once the problem with CAR loading the CDR records has been resolved. From then on you should simply be able to create and run reports from the CDR database as you would normally.
