Cat4500 port config for phones
I'm starting a VoIP deployment and have a question on basic port configuration. Should I configure the port as a trunk port? The phones will have PCs attached. This is what I've done so far.
interface FastEthernet5/48
switchport trunk native vlan 30
switchport mode trunk
switchport voice vlan 31
qos trust device cisco-phone
qos trust cos
service-policy output autoqos-voip-policy
no snmp trap link-status
auto qos voip cisco-phone
tx-queue 3
priority high
shape percent 33
spanning-tree portfast
Does anyone see a problem? Should I do this another way?
Patrick
Re: Cat4500 port config for phones
The answer is...IT DEPENDS on what model switch are you placing the phones? The configuration you have put forward appears to be for an older model (say, a Cat 3524XL). The newer Cat 3550-24PWR switch recommends dispensing with 802.1Q trunking mode altogether and configuring an access (native) vlan and a voice vlan. Thus, PHONE ports would be configured as follows
mls qos trust cos
switchport access vlan 11
switchport voice vlan 111
switchport priority extend cos 0
priority-queue out
wrr-queue cos-map 4 5
spanning-tree bpduguard enable
(on the global config level, you would enable qos and map cos to dscp values 0 8 16 26 34 46 48 56)
On a Cat 4000/4500 series switch, the commands are slightly different:
qos trust cos
qos trust extend cos 0
tx-queue 3
priority high
(again, globally enable qos and map cos to the same DSCP values as above)
As I understand it, CDPv2 is used at the link layer level to negotiate power, duplex, VTP domain and tagged VLAN information with a directly connected IP phone (the last item, however, is negotiated ONLY for switchports that are CAPABLE OF SUPPORTING 802.1Q, even though they are not explicitly configured for trunking!) 802.1Q tagged frames are then processed by the IP phone itself, whereas untagged (native/access VLAN) frames are passed to the local PC switch port on the phone. (In my experience, however, I have found that ATA18X analog gateways do not successfully negotiate the tagged voice VLAN -- in which case, you must configure the voice VLAN as the access VLAN.)
Also, as of CallManager 3.0(5), the CallManager server itself sets Cos and DSCP values for all registered IP phones and SCCP gateways, and they are user-configurable under the CallManager Service Parameters. If H323 and MGCP gateways are set up properly, they too will classify voice signaling and bearer traffic correctly. Therefore, there is no longer any need to place service output policies on ports directly connected to these devices.
Thank you rmwall,
I got the other port config from a 3524XL. I changed my phone port config to look like this.
interface FastEthernet6/24
switchport access vlan 30
qos trust cos
tx-queue 3
priority high
shape percent 33
--Patrick
229
