Catalyst 3550PWR - IP Phone - power watts by phone
HI,
Need to choose some UPS model to backup the electrical source on some 3550PWR which connect IP phone. I know that Inline Power modules on Cat6K will deliver the exact amount of watt needed by Ip phone (IP phone tell the switch their power requirement via CDP).
Can somebody confirm me that 3550PWR will do the same, so that I can really consider the exact need of 6.3 watts instead of 15 watts (maximum by port) for calculating the power budget.
Thanks.
Silver
Re: Catalyst 3550PWR - IP Phone - power watts by phone
I guess it is the same 6.3 watts for Cat 3550 also
show inline power status - for Cat OS
Show env power
I found the 3550 Command Reference. There is a "power inline" command, but there is not an option to adjust the power level. I have copied the power inline command below.
power inline
Use the power inline interface configuration command to set the inline-power state on the
inline-power-capable interfaces on the Catalyst 3550-24PWR switches.
power inline {auto | never} | [delay {shutdown seconds initial seconds}]
Note This command is available only on the Catalyst 3550-24PWR switches.
Syntax Description
Defaults The default for inline-power capable interfaces is auto.
No delay time is configured.
Command Modes Interface configuration
Command History
Usage Guidelines When using a Cisco Power Device, the delay shutdown command is not needed. Although you can
configure a delay shutdown time, it does not take any action on a connected Cisco device.
The delay shutdown command is only recommended for certain IEEE Power Devices that require
multiple reloads during initialization. Use the delay shutdown seconds initial seconds keywords to
configure the switch to continue providing power during initialization. Without using the delay
shutdown command, the switch removes power immediately when linkdown occurs on the connected
device.
Caution To avoid product damage, you should not connect any non-IEEE Power Device during the delay
shutdown time interval. When the delay shutdown command is active on a port, the port remains
powered after unplugging the IEEE Power Device for the configured time interval.
auto Automatically detect and power inline devices.
never Disable the detection and power for the inline-power-capable interface.
delay (Optional) Configure a power shutdown delay time.
shutdown seconds Configure the time that the switch continues to provide power to the device
after linkdown. The range is 0 to 20 seconds.
initial seconds Configure an initial time that the power shutdown delay is in effect. The
range is 0 to 300 seconds.
Release Modification
12.1(12c)EA1 This command was first introduced.
12.1(19)EA1 The delay shutdown seconds initial seconds keywords were added.
327
