Community Member
Catalyst 4006 Series Switches
Can someone tell me how many c4gwy blades can exist in a 4006? Right now, we have two 4006s each with a Supervisor engine and a c4gwy. Each c4gwy has two digital T1s, since that is all a c4gwy supports. We need more digital T1 density and would like to fill the remaining 4 blades with more c4gwys.
WB
1 ACCEPTED SOLUTION
Community Member
Re: Catalyst 4006 Series Switches
I am using three numbers of cat 4000 AGM modules in my setup. And in case you are using the all the T1 lines for Data in that case, You need a 48 Port inline Fast ethernet card for your setup to handle the bulk traffic.
And it can support five numbers of Cat 4k AGM as T1 lines restriction is dependent on the AGM module and not on the Cat 4006 chassis
Hope this helps
1 REPLY
Community Member
Hope this helps
108
