Bronze
catalyst 500 POE cable pinouts
I read that the catalyst 500 supports both 802.3af and cisco pre-standard but I need to verify which cable pins the catalyst 500 is using to power a Cisco Phone.
I assume it will be either 1, 2, 3, 6 or 4, 5, 7, 8.
1 REPLY
Hall of Fame Super Red
Re: catalyst 500 POE cable pinouts
Hi Shane,
Here is a reference guide for the Catalyst 500 which shows that the pins being used are 1,2,3,6 as you suggested.
User Guide for the Catalyst Express 500 Switches
From this doc;
http://www.cisco.com/en/US/products/ps6545/products_user_guide_chapter09186a0080531d83.html#wp1007834
Hope this helps!
Rob
Please remember to rate helpful posts........
380
