01-16-2004 08:13 AM - edited 03-13-2019 03:23 AM
Hello ,
I have a Catalyst 5509 .Can I use power patch panel to get inline power for IP phones or for access points.
Thanks .
01-16-2004 11:43 AM
I don't believe the 5000/5500 series supports inline power modules. You would have to go with the 4500 or 6500 series. Not to mention the 5000/5500 series devices are EOL.
01-16-2004 02:04 PM
Yes, you can use a Catalyst Inline Power Patch Panel to supply power to IP Phones for any Catlyst switch that dosent supply Inline Power through the modules.
