Cause i = 0x80AC - Requested circuit/channel not available
I am receiving the following error at apparently random times:
People try to call in, get a fast busy sometimes, but sometimes connect.
Here are parts of my config:
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice service voip
fax protocol pass-through g711ulaw
voice class codec 101
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 1
rule 1 /removed\(....\)/ /\1/
rule 2 /removed/ /2900/
rule 4 /removed/ /2310/
rule 5 /removed/ /2601/
rule 6 /removed/ /2900/
rule 7 /removed/ /2311/
rule 8 /removed/ /2312/
voice translation-rule 2
rule 1 /^011\(44.+\)/ /\1/ type any international plan any isdn
voice translation-profile Incoming-DID
translate called 1
voice translation-profile Outgoing-ISDN
translate called 2
controller T1 0/2/0
framing esf
clock source line primary
linecode b8zs
pri-group timeslots 1-24
description PRI
controller T1 0/2/1
framing esf
linecode b8zs
interface Serial0/2/0:23
no ip address
isdn incoming-voice voice
no cdp enable
voice-port 0/2/0:23
translation-profile incoming Incoming-DID
translation-profile outgoing Outgoing-ISDN
dial-peer voice 1025 voip
destination-pattern 25[3-8].
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1029 voip
destination-pattern 2900
incoming called-number 2900T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 pots
destination-pattern .+T
direct-inward-dial
port 0/2/0:23
forward-digits all
dial-peer voice 2310 voip
destination-pattern 2310
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2311 voip
destination-pattern 2311
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2312 voip
destination-pattern 2312
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2601 voip
destination-pattern 2601
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 101 voip
voice-class codec 101
incoming called-number .+T
dtmf-relay rtp-nte
sip-ua
sip-server ipv4:address removed
more to follow
Re: Cause i = 0x80AC - Requested circuit/channel not available
here are parts of my debug:
Oct 16 12:23:08.147: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x08E0
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A1080201010201008400
Protocol Profile = Networking Extensions
0xA1080201010201008400
Component = Invoke component
Invoke Id = 1
Operation = CallingName
Name not available
Calling Party Number i = 0x00C3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, 'removed'
Plan:ISDN, Type:National *Oct 16 12:23:08.151:
//-1/xxxxxxxxxxxx/VTSP:(0/2/0:23):-1:-1:-1/vtsp_allocate_cdb:
CDB=0x666105A8
//-1/xxxxxxxxxxxx/VTSP:(0/2/0:23):-1:-1:-1/vtsp_do_call_setup_ind:
Event=E_TSP_SETUP_IND
Progress Indication=0, CarrierIDCode=, Info Trans Capability=0, Source Carrier ID=, tg_label_flag=0 *Oct 16 12:23:08.151:
Called Number=2900, TON=National, NPI=ISDN *Oct 16 12:23:08.151:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_do_normal_call_setup_ind:
*Oct 16 12:23:08.151: //-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_timer:
Timer Start Time=163369438, Timer Value=180000(ms) *Oct 16 12:23:08.151:
IC State Machine (ICSM) Added
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_insert_cdb:
*Oct 16 12:23:08.151: flex_dsprm_vtsp_open - ACTIVE CALL *Oct 16
12:23:08.151:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_dsm_opened_cb:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_process_event:
[state:S_SETUP_IND_PEND, event:E_VTSP_DSM_OPEN_FAILURE] *Oct 16
12:23:08.151:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/act_setup_ind_pend_failure:
Cause Value=172
*Oct 16 12:23:08.151: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x88E0
Cause i = 0x80AC - Requested circuit/channel not available *Oct 16
12:23:08.151:
[state:S_SETUP_FAIL, event:E_TSP_DISCONNECT_CONF] *Oct 16 12:23:08.151:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/act_setup_fail:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/act_setup_fail:exit@475
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/act_terminate:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_set_release_source:
Release Direction=PSTN, Release Source=Calling Party-PSTN *Oct 16
12:23:08.151:
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_timer_stop:
Timer Stop Time=163369438
//-1/EA559B8288E1/VTSP:(0/2/0:23):0:-1:-1/vtsp_free_cdb:
CDB=0x666105A8
NOTE: Anywhere you see removed is because I removed the address/phone number.
Anyone have any idea what I need to do?
Just so everyone knows, there is a bug in the IOS. I know, I am just as surprised as everyone else is!
The bug id is CSCsb12638
No need to reply to this thread.
4011
