Cause i = 0x80E4 - Invalid information element contents in debug isdn q931
5350 is configured with T1 PRI. i did the debug isdn q931 and i found this message in every call. Calls are coming and going out properly. A little debug isdn q931 for your consideration:
*Mar 21 08:29:35: ISDN Se3/0:23: overriding plan/type for 0292299128, isdn/national to isdn/subscriber
*Mar 21 08:29:35: ISDN Se3/0:23: overriding plan/type for 0292299128, data/unknown to isdn/subscriber
*Mar 21 08:29:35: ISDN Se3/0:23: TX -> SETUP pd = 8 callref = 0x6562
*Mar 21 08:29:35: Bearer Capability i = 0x8090A2
*Mar 21 08:29:35: Channel ID i = 0xA98397
*Mar 21 08:29:35: Calling Party Number i = 'A', 0x83, '0292299128', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:29:35: Called Party Number i = 0xC1, '49146467', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:29:35: ISDN Se3/0:23: RX <- CALL_PROC pd = 8 callref = 0xE562
*Mar 21 08:29:35: ISDN Se3/0:23: RX <- PROGRESS pd = 8 callref = 0xE562
*Mar 21 08:29:35: Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 21 08:29:42: ISDN Se3/0:23: RX <- SETUP pd = 8 callref = 0x7E7A
*Mar 21 08:29:42: Bearer Capability i = 0x8090A2
*Mar 21 08:29:42: Channel ID i = 0xA98381
*Mar 21 08:29:42: Calling Party Number i = 0x00A0, '009001', Plan:Unknown, Type:Unknown
*Mar 21 08:29:42: Called Party Number i = 0xC1, '49204337', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:29:42: ISDN Se3/0:23: TX -> CALL_PROC pd = 8 callref = 0xFE7A
*Mar 21 08:29:43: ISDN Se3/0:23: RX <- ALERTING pd = 8 callref = 0xE562
*Mar 21 08:29:44: ISDN Se3/0:23: RX <- DISCONNECT pd = 8 callref = 0x7E7A
*Mar 21 08:29:44: Cause i = 0x80A930 - Temporary failure
*Mar 21 08:29:44: ISDN Se3/0:23: TX -> RELEASE pd = 8 callref = 0xFE7A
*Mar 21 08:29:44: Cause i = 0x80E4 - Invalid information element contents
*Mar 21 08:29:44: ISDN Se3/0:23: RX <- RELEASE_COMP pd = 8 callref = 0x7E7A
*Mar 21 08:29:45: ISDN Se3/1:23: RX <- SETUP pd = 8 callref = 0x34A0
*Mar 21 08:29:45: Bearer Capability i = 0x8090A2
*Mar 21 08:29:45: Channel ID i = 0xA98381
*Mar 21 08:29:45: Calling Party Number i = 0x80, '0821653159', Plan:Unknown, Type:Unknown
*Mar 21 08:29:45: Called Party Number i = 0xC1, '992955993', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:29:45: ISDN Se3/1:23: TX -> CALL_PROC pd = 8 callref = 0xB4A0
*Mar 21 08:29:45: Channel ID i = 0xA98381un all
*Mar 21 08:29:50: ISDN Se3/1:23: TX -> ALERTING pd = 8 callref = 0xB4A0
*Mar 21 08:29:50: Progress Ind i = 0x8188 - In-band info or appropriate now available
*Mar 21 08:29:56: ISDN Se3/1:23: TX -> CONNECT pd = 8 callref = 0xB4A0
*Mar 21 08:29:56: Progress Ind i = 0x8182 - Destination address is non-ISDN
*Mar 21 08:29:56: ISDN Se3/1:23: RX <- STATUS pd = 8 callref = 0x34A0
*Mar 21 08:29:56: Cause i = 0x80E31E - Information element not implemented
*Mar 21 08:29:56: Call State i = 0x08
*Mar 21 08:29:56: ISDN Se3/1:23: RX <- CONNECT_ACK pd = 8 callref = 0x34A0
*Mar 21 08:29:56: ISDN Se3/1:23: CALL_PROGRESS: CALL_CONNECTED call id 0x1B6E, bchan 0, dsl 1
*Mar 21 08:30:05: ISDN Se3/0:23: RX <- CONNECT pd = 8 callref = 0xE562
*Mar 21 08:30:05: ISDN Se3/0:23: TX -> CONNECT_ACK pd = 8 callref = 0x6562
*Mar 21 08:30:07: ISDN Se3/0:23: TX -> DISCONNECT pd = 8 callref = 0x6562
*Mar 21 08:30:07: Cause i = 0x8090 - Normal call clearing
*Mar 21 08:30:08: ISDN Se3/0:23: RX <- RELEASE pd = 8 callref = 0xE562
*Mar 21 08:30:08: ISDN Se3/0:23: TX -> RELEASE_COMP pd = 8 callref = 0x6562
*Mar 21 08:30:24: ISDN Se3/1:23: RX <- DISCONNECT pd = 8 callref = 0x34A0
*Mar 21 08:30:24: Cause i = 0x809F30 - Normal, unspecified
*Mar 21 08:30:24: ISDN Se3/1:23: TX -> RELEASE pd = 8 callref = 0xB4A0
*Mar 21 08:30:24: Cause i = 0x80E4 - Invalid information element contents
*Mar 21 08:30:24: ISDN Se3/1:23: RX <- RELEASE_COMP pd = 8 callref = 0x34A0
*Mar 21 08:30:27: ISDN Se3/0:23: overriding plan/type for 0292299128, isdn/national to isdn/subscriber
*Mar 21 08:30:27: ISDN Se3/0:23: overriding plan/type for 0292299128, data/unknown to isdn/subscriber
*Mar 21 08:30:27: ISDN Se3/0:23: TX -> SETUP pd = 8 callref = 0x6563
*Mar 21 08:30:27: Bearer Capability i = 0x8090A2
*Mar 21 08:30:27: Channel ID i = 0xA98397
*Mar 21 08:30:27: Calling Party Number i = 'A', 0x83, '0292299128', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:30:27: Called Party Number i = 0xC1, '47446467', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:30:27: ISDN Se3/0:23: RX <- CALL_PROC pd = 8 callref = 0xE563
*Mar 21 08:30:27: ISDN Se3/0:23: RX <- PROGRESS pd = 8 callref = 0xE563
*Mar 21 08:30:27: Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 21 08:30:35: ISDN Se3/0:23: RX <- ALERTING pd = 8 callref = 0xE563
*Mar 21 08:30:35: ISDN Se3/0:23: RX <- CONNECT pd = 8 callref = 0xE563
*Mar 21 08:30:35: ISDN Se3/0:23: TX -> CONNECT_ACK pd = 8 callref = 0x6563
*Mar 21 08:30:36: ISDN Se3/0:23: overriding plan/type for 0292399766, isdn/national to isdn/subscriber
*Mar 21 08:30:36: ISDN Se3/0:23: overriding plan/type for 0292399766, data/unknown to isdn/subscriber
*Mar 21 08:30:36: ISDN Se3/0:23: TX -> SETUP pd = 8 callref = 0x6564
*Mar 21 08:30:36: Bearer Capability i = 0x8090A2
*Mar 21 08:30:36: Channel ID i = 0xA98396
*Mar 21 08:30:36: Calling Party Number i = 'A', 0x83, '0292399766', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:30:36: Called Party Number i = 0xC1, '494190579', Plan:ISDN, Type:Subscriber(local)
*Mar 21 08:30:36: ISDN Se3/0:23: RX <- CALL_PROC pd = 8 callref = 0xE564
*Mar 21 08:30:36: ISDN Se3/0:23: RX <- PROGRESS pd = 8 callref = 0xE564
*Mar 21 08:30:36: Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 21 08:30:39: ISDN Se3/0:23: RX <- ALERTING pd = 8 callref = 0xE564
*Mar 21 08:30:49: ISDN Se3/0:23: RX <- DISCONNECT pd = 8 callref = 0xE563
*Mar 21 08:30:49: Cause i = 0x809030 - Normal call clearing
*Mar 21 08:30:49: ISDN Se3/0:23: TX -> RELEASE pd = 8 callref = 0x6563
*Mar 21 08:30:49: Cause i = 0x80E4 - Invalid information element contents
*Mar 21 08:30:49: ISDN Se3/0:23: RX <- RELEASE_COMP pd = 8 callref = 0xE563
*Mar 21 08:30:50: ISDN Se3/1:23: RX <- SETUP pd = 8 callref = 0x35A0
*Mar 21 08:30:50: Bearer Capability i = 0x9090A2
*Mar 21 08:30:50: Channel ID i = 0xA98381
Configuration:
interface Serial3/0:23
no ip address
no logging event link-status
isdn switch-type primary-dms100
isdn not-end-to-end 64
isdn incoming-voice modem 64
isdn map address .* plan isdn type subscriber
fair-queue 64 256 0
no cdp enable
interface Serial3/1:23
no ip address
fair-queue 64 256 0
no cdp enable
voice-port 3/0:D
echo-cancel coverage 16
timeouts initial 30
timeouts interdigit 5
timeouts ringing 30
bearer-cap Speech
voice-port 3/1:D
timeouts initial 30
timeouts ringing 30
bearer-cap Speech
System image file is "flash:c5350-is-mz.121-5.XM8.bin" default with my 5350.
Any help will higly be appriciated. Thanks
  • Other Collaboration Voice and Video Subjects
Re: Cause i = 0x80E4 - Invalid information element contents in d
Looks like it is from the router side:
0x80E4
The remote equipment receives a message that includes invalid information in the information element.
This cause indicates that the equipment sending this has received an information element which it has implemented; however, one or more of the fields in the information element are coded in a way that has not been implemented by the equipment sending this cause.
This is due to a D-channel error
http://www.cisco.com/warp/public/129/isdn_disc_code.html
Hey,
thanks for your attention. I was thinking to give some more details on network topology.
Originating site--------------------Internet--------------------Terminating side
E1 PRI (basic-net3)-------------------------------------------- T1 PRI (primary-dms100)
Originating side config:
interface Serial0:15
no ip address
isdn switch-type primary-net5
isdn overlap-receiving
isdn protocol-emulate network
isdn T310 60000
no isdn outgoing display-ie
fair-queue 64 256 0
no cdp enable
voice-port 0:D
cptone FR
timeouts initial 30
timeouts ringing 60
timeouts wait-release 3
bearer-cap Speech
ISDN 0:D - 0:D
Type of VoicePort is ISDN
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 16 ms
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 200 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 30 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 60 s
Wait Release Time Out is set to 3 s
Companding Type is A-law
Region Tone is set for FR
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Terminating Side Config:
no ip address
fair-queue 64 256 0
no cdp enable
voice-port 3/0:D
timeouts initial 30
timeouts ringing 30
bearer-cap Speech
ISDN 3/0:D - 3/0:D
Playout-delay Mode is set to default
Interdigit Time Out is set to 5 s
Ringing Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Wait Release Time Out is 30 s
Hope this might help us to solve the issue.
5437
