Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CCM 3.1(3a) and a 1760 16 port FXO
What version CCM can I configure a 1760 16 ports FXO gateway on?
I would like to configure a 1760 with four 4port FXO cards. Each 4 port card must be able to be divided into two separate FXO H323 gateways on each 4 port card.
In other words I would like to get 8 different H323 gateways on the 1760, each gateway using/alternating between 2 FXO ports.
Is this even possible to do?
Rob
1 REPLY
Silver
Re: CCM 3.1(3a) and a 1760 16 port FXO
From the CCM's perspective, the 1760 would behave as a single H.323 gateway only. However, if your intention is to have select numbers for a set of
fxo ports, create one route-pattern for each set of fxo port and configure the dial-peers in the 1760 appropriately to handle this.
Another option is to use DNS. Have 8 DNS entries for the same 1760 and use the above mentioned dial-peer configurations. CCM 3.1(3a) that you have is fine for the above solutions.
91
