09-17-2002 07:04 AM - edited 03-12-2019 08:48 PM
I was wondering how to disable the comfort noise in 3.2.2 call manager, when I call unity, there is alot of "white noise" how can this be disabled?
Solved! Go to Solution.
09-23-2002 10:47 AM
To disable comfort noise on your Call Manager, make sure that you have the following parameters in your Call Manager set to false:
SilenceSupressionSystemWide
SilenceSupressionWithGateways
You can find these parameters by selecting Service> Service Parameters and Select Cisco Call Manager.
09-23-2002 10:47 AM
09-24-2002 03:44 PM
Thanks for the response, the problem was the TSP wave driver, I reinstalled the latest version and the "white-noise" was gone.
10-04-2002 05:26 AM
For these two parameters :
When comfort noise is dasabled, when the parameter is true, or when is false, because the descritpion in help sounds too ambiguous.
10-04-2002 06:23 AM
when these two parameters are set to false, comfort noise or white noise will get disabled
