CCM 3.3.3 SQL subscription
Hi, I've just completed an upgrade from CCM 3.3.2 to 3.3.3 on a publisher and single subscriber. I had to manually re-establish the pull subscription from the subscriber. All appears to be working ok except that if I open SQL Enterprise Manager and look at the Job History for the subscription it says it's "in progress" and in the bottom window "The initial snapshot for publication 'CCM0301' is not yet available".
I left this overnight and the elapsed time is still incrementing but the messages are the same.
Is this normal or do I have a problem?
Any ideas?
Thanks, Des.
1 REPLY
Re: CCM 3.3.3 SQL subscription
Just had an answer from TAC. I missed step 10 on the following instruction :-
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080094aeb.shtml
Worked fine after that.
Hope this helps anybody with similar problem.
Des.
82
