10-28-2003 08:38 AM - edited 03-13-2019 02:18 AM
during the ccm install of my subscriber server i get an error messege saying my private password phrase doesnt match. even though i didnt forget what it was when i loaded the publisher server with ccm. when i try to reset the passwords on the publisher using the call manager admin utility it seems to just sit there for a long time without ever actually changing the passwords.
the servers are not set up on a domain. they are set up as workgroups.
i also have them connected with a crossover cable and they do see each other. i had them on the network as well, but it still made no difference.
10-28-2003 09:08 AM
Can you verify that you have a lmhosts and a hosts entry on both servers.
10-28-2003 09:13 AM
i did add the hostnames of both servers in the etc host file.
10-28-2003 09:26 AM
It needs to be in the LMHosts file as well. What service does it get stuck on when changing the password?
10-28-2003 09:43 AM
the lmhost entry was added.
i'm not sure what service it is. its before the ccm install and it's the first window for the private password phrase.
02-27-2004 02:46 AM
Hi, We`ve the same problem than you.
We add entries for host and lmhost, The publicher is in a workgroup, and the connectivity is right...
We run adminutility, use the new password option and then use this password in subscriber, but the problem persist.
Some idea?
Thanks.
