CCM 3.3(3) Subscriber problem
during the ccm install of my subscriber server i get an error messege saying my private password phrase doesnt match. even though i didnt forget what it was when i loaded the publisher server with ccm. when i try to reset the passwords on the publisher using the call manager admin utility it seems to just sit there for a long time without ever actually changing the passwords.
the servers are not set up on a domain. they are set up as workgroups.
i also have them connected with a crossover cable and they do see each other. i had them on the network as well, but it still made no difference.
Bronze
Re: CCM 3.3(3) Subscriber problem
Can you verify that you have a lmhosts and a hosts entry on both servers.
i did add the hostnames of both servers in the etc host file.
Bronze
It needs to be in the LMHosts file as well. What service does it get stuck on when changing the password?
the lmhost entry was added.
i'm not sure what service it is. its before the ccm install and it's the first window for the private password phrase.
Hi, We`ve the same problem than you.
We add entries for host and lmhost, The publicher is in a workgroup, and the connectivity is right...
We run adminutility, use the new password option and then use this password in subscriber, but the problem persist.
Some idea?
Thanks.
104
