10-09-2006 01:04 PM - edited 03-13-2019 03:17 PM
Hello guys,
I am in a desperate need of full install version of CallManager 3.3 and Unity 4.0. I wasn't able to find them in the software download section. Could you please let me know how can I get those downloads?
10-09-2006 01:30 PM
You cannot download CCM software directly only some upgrades.
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-33
Follow this link to get CDs.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
You can download from here: Unity 4.0.5.
http://www.cisco.com/cgi-bin/Software/Tablebuild/tablebuild.pl/4yutni0
10-09-2006 01:31 PM
You cannot download callmanager software (only patches and maintenance upgrades). You have to order the disks.
With Unity you can download images from Unity archives. They recommend that you do not use this for upgrades though.
Sankar
PS: please remember to rate posts!
10-09-2006 01:47 PM
I have a cisco 2651 with CME 3.3 configurated and I want to create an auttoatendant with virtual secretary, telling to press buttons for connecting to the desired department.
I don't know how can I start configuring it.
Which is the default option?
Do I need the unity software?
How can I install in the router ?
Is free if you have CME in the router?
Could you help me to discover this issue?
This is my router versions:
isco IOS Software, C2600 Software (C2600-JSX-M), Version 12.4(1), RELEASE SOFTW
ARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 29-Apr-05 16:28 by hqluong
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 56 minutes
System image file is "flash:c2600-jsx-mz.124-1.bin"
Cisco 2651XM (MPC860P) processor (revision 0x400) with 253952K/8192K bytes of me
mory.
Processor board ID JHY0904K0YP (2075692498)
M860 processor: part number 5, mask 2
1 Ethernet interface
2 FastEthernet interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
And telephony services:
Version 3.3
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 192.168.3.1 port 2000
max-ephones 2
max-dn 2
max-conferences 4 gain -6
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
network-locale ES
user-locale ES
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
keepalive 30
timeout interdigit 10
timeout busy 10
aller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web: disabled.
edit TIME through web: disabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp Jan 01 2002 00:00:00
transfer-system full-consult
auto assign 1 to 2
local directory service: enabled.
Could you give me an example?
This is my cme configuration:
dial-peer voice 100 voip
translation-profile outgoing SIPout
destination-pattern 9........
session protocol sipv2
session target sip-server
codec g711ulaw
dial-peer voice 101 voip
destination-pattern 6........
codec g711ulaw
sip-ua
authentication username 964812530 password 03256C2A5E5E6B1B16584146
retry register 10
registrar ipv4:213.162.201.146 expires 60
sip-server ipv4:213.162.201.146
gatekeeper
shutdown
telephony-service
max-ephones 2
max-dn 2
auto assign 1 to 2
user-locale ES
network-locale ES
ephone-dn 1 dual-line
number 200 no-reg primary
label Tecnicos
label Tecnicos
ephone-dn 2 dual-line
number 201 no-reg primary
label Comercial
ephone 1
mac-address 0013.60C3.CE02
type 7902
button 1:1
ephone 2
mac-address 0012.431E.BF3E
type 7902
button 1:2
10-09-2006 09:05 PM
You dont need Unity software.You may want to use a TCL script for AA.
Check out that post for more info.
10-10-2006 02:50 AM
Is there any script by default uploaded in the router?
I'm trying to download the ones that tells in the link but it's not possible.
