CCM 3.33 and 3.02 CRA
I am not sure but I think I have to upgrade CRA to 3.03a while upgrading CCM to 3.33 I am at 3.22c on CCM is there a problem with going straigh to 3.33.
1 REPLY
Bronze
Re: CCM 3.33 and 3.02 CRA
As per the Cisco Callmanager Compatibility matrix CRS 3.0(2) is not supported with CCM 3.3(3) where as CRS 3.0(3a) is compatible with CCM 3.2(2c) co-located or standalone with spF.
Check out the compatibility matrix
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
You should upgrade your CRS to 3.0(3a) first and then upgrade CM 3.2(2c) to CM 3.3(3).
All Installations of 3.0(3) are documented in the Getting started Guide. The process is the same for upgrades and new installs. Documentation link for CRA 3.0(3) Installation.
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_3_0/english/admn_app/getst303/getst3.pdf
Documentation link for upgrading CallManager
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/install/upgrade/index.htm
Venkat
79
