CCM 4.1(3) Installation Issues
Hi everybody.
This document about Replacing hardware during the CCM 4.1(3) upgrade (http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/install/upgrade/upg413/replace.htm) states that to import a CCM 3.3(5) backup, made with BARS 4.0(8), i need to use the Operating System CD version 2000.2.4.
The server that came with CCM 4.1(3) is a MCS 7835-H1 (DL380 G4) and the OS CDs version 2000.2.4 in the CCM 4.1(3) bundle don't support this hardware.
If I install the server with OS CDs/DVDs version 2000.2.7 everything goes fine, but I'm unable to import a CCM 3.3(5) backup with BARS in a CCM 4.1(3) fresh installation due to a CCM version mismatch.
Any suggestions?
Thanks in advance
1 REPLY
Bronze
Re: CCM 4.1(3) Installation Issues
You can only restore to the same CCM version.
So you have 2 options.
1 - Build a new server with 3.3(5) using 2000.2.7(If old server has SRs don't forget to install them in the new server). Restore 3.3(5) database. And upgrade to 4.1(3).
2 - You can upgrade existing box to 4.1(3). Make a backup using BARS. Build new server with 4.1(3). And restore 4.1(3) database.
I recently performed upgarde from 3.3(4) to 4.1(2) replacing servers. I used option 1.
Hope that helps.
98
