CCM 4.1(3) multiply T1s, PRI, routing with CMM card
I have the following hooked up and working currently:
CCM 4.1(3)
(2) CMM blades in 6509
(4) PRIs (2 in each CMM blade)
(1) Tie line gateway for remote office connections
My client wants to add (2) T1 lines into the CMM and route only long distance calls on this for outbound. Other offices have the same provider at their end so it stays on the providers circuits and cheaper LD rates.
To force Site A with CCM and CMM to have all LD calls route outbound, do I need to setup a route pattern for LD and local?
Local would be 715 and 920, all others would be LD.
Local 91715xxxxxxx use the PRI
91920xxxxxxx use the PRI
LD 91??????????? use the dedicated circuit xyz
Do I need to list out all the patterns for this to seperate my route pattens for each gateway or is their an easier way?
Thanks much
Re: CCM 4.1(3) multiply T1s, PRI, routing with CMM card
I think you need to configure a list of route patterns/route lists to select the appropriate gateways
Blue
what you should do is define a CSS and partitions for each site.
then you define routePatterns for each site, using the site specific partitions.
this way, you'll be able to direct siteA LD calls out a specific PRI while allowing other sites to use other gateways for their LD calls.
if you need an example, let me know and i'll type one up! :)
NOTE: with this type of heirarchy, you will have multiple routePatterns of the same digits.
ie:
91xxxxxxxxxx - PT_SiteA
91xxxxxxxxxx - PT_SiteB
201
