Community Member
CCM 4.1.3 Redundancy issue
I've installed 2 CCMs Pub and Sub. But i cannot access admin page (Error 500) on Sub and i cannot start some services on Sub, also ( Call manager, CTI manager, Extended functions, IP Voice Media Streaming App, Messaging Interface)
Are there any services that not need to run on SUB or any special config of SUB
Any experiences aor ideas
Thanx
Vlad
Bronze
Re: CCM 4.1.3 Redundancy issue
Can you give us more detail?
Do you get error when you install sub?
First of all, you should install Pub first. Then during installation of Sub, you should been asked to enter "sa" password to get the database from Pub.
Community Member
I did everything properly, and databases are published
and subscribed, replicated, it's not an issue
SERVICES are, they won't start
Is this the problem that you are seeing:
HTTP 500 - Internal Server Error
If yes, then follow this link:
http://support.microsoft.com/default.aspx?scid=kb;en-us;327153
Community Member
Thanx man, i already found that on microsoft, but will try tomorow! Do U have any ideas about services that doesn't start, it's bigger problem
Thanx
I'd say start with the app logs to see if anything obvious shows. One question about the cluster - after you finished, did you reboot the ENTIRE cluster?
Community Member
Sub was restarted right after CCM installation was finished, but after booting up i shutdown whole cluster
Do U think i should reinstall SUB or whole cluster
or ...
Thanx
123
