Community Member
CCM 4.1(3)sr2 and MGCP Gateway C2621-XM
Hi.
I have a Cisco 2621XM with a NM-HDV2-1T1/E1 configured on the CallManager as a MGCP gateway. The MGCP gateway T1/PRI endpoint shows up on the correct slot 1/0. That is the onboard T1 port within the NM. Now I would like to add another VWIC-1MFT-T1 to the VIC available on the NM-HDV2 card but when I add that on CallManager it also shows up at 1/0.
Any ideas? If I add a VIC2-4FXO on the CCM web page it add the ports as 1/0/0-1/0/3.
Thanks in advanced,
-Jose
Community Member
Re: CCM 4.1(3)sr2 and MGCP Gateway C2621-XM
Copy paste the show diag from 2621xm
Check this screenshot. Change the begin port to 1 for the vic slot on the nm-hdv2.
Sankar
PS: please remember to rate all posts!
Community Member
I will try that when I get a chance. I haven't insert the VWIC yet on the router so I don't know if the router will put it on 1/1 or on 1/0/0.
I'll let you know..
-Jose
Community Member
attach sh tech from the router 2621xm....
159
