you shouldn't need NAT here.
if your 192.168.50.x/24 subnet steps on parts of their network, which it doesn't in the diagram you provided, then use another class such as 172.16.1.x/24 or 10.1.1.x/24. (this would be the easiest configuration for placing into their network; they would have to add routes to their network for a different class)
1) connect your ccm server and ip phone1 to switch1 (192.168.50.x/24) subnet.
2) connect your ip phone2 to switch2 (192.168.2.x./24) subnet.
3) obtain ip addresses from the respective subnets to the server and two ip phones.
4) statically configure the phones with ip, subnetMask, router and TFTP server. (tftp could be your ccm server)
5) configure call manager for the phones and gateway and dial plan. (gateway probably h323; may be able to use MGCP)
6) configure gateway with POTS dialpeers(unless pbx supports IP, then you may be able to use a VoIP dialPeer), for calls to the PBX via T1/FXO
7) configure PBX dial plan for DN 501 & 502 via the T1/FXO to voip network
8) assure ip routing is possible between the ccm server and ip phones with ping or by other means
9) test calls
NOTES:
* QoS will not be possible if they will not change any router/switch configuration.
