CCM and SRST deployment over several countries
I will have to deploy Cisco ToIP over several countries. The infrastructure is a CCM cluster (1 publisher and 2 subscribers 7845) based in one country (Core System)and the other countries will be connected via SRST.
Do you know if it exist a Best Pratice Document within Cisco?
Thanks by advance for your help,
JP
Re: CCM and SRST deployment over several countries
Blue
since you'll be using the routers at the other countries as SRST routers, it would probably be best as well, and a best practice, to use the routers as Call Manager Express solutions.
either way can support h323, sccp, rtp, PRI/BRI, etc. as well as provide more/easier flexibility with the dial plan. (more flexability may require more complexity though)
please use the SRND links provided above to verify the design as well as the following links for CME:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_configuration_examples_list.html
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_installation_and_configuration_guides_list.html
& unity express:
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_implementation_design_guides_list.html
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_installation_and_configuration_guides_list.html
And you could use an H323 intercluster trunk with the CM
Greetings
Rodrigo
114
