Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CCM and Unity Patches
Folks,
I really need some help. we have 2 clusters of (callmanagers + unity) at 2 different locations. I have not done anything as far as patches or secuirty undates go for atleast 1 year.
Does anyone have a procedure of how to go about applying patches to the ccm and unity, what about secuity patches, how do i know where i am and what should i install.
Any help would be highly appreciated.
I will surely undate this post.
Tarun
Re: CCM and Unity Patches
Tarun,
Take a look at the links below. The first two give the recommended service packs and patches for Unity and CCM. The last gives instructions for finding your current OS level and applying the necessary service packs and patches.
Recommended Service Packs and Updates for Use with Cisco Unity and the Cisco Unity Bridge
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/cmptblty/msupdate.htm
Cisco IP Telephony Operating System, SQL Server, Security Updates
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/osbios.htm
Installing the Operating System on the Cisco IP Telephony Applications Server
http://www.cisco.com/univercd/cc/td/doc/product/voice/iptel_os/install/os200027.htm
Hope this helps. If so, please rate the post.
Brandon
Follow the patches that are posted to your reply. But remember.... Do not use Terminal Service to apply your patches. You must have console access to apply theses patches. (IPKVM or third party software such as VNC, pcAnywhere, etc)
cheers!
tc
I am presently running the following versions:
Call manager: 4.1(3)
OS Image: 2000.2.4
OS service Release: 2000.2.7.sr6
OS Upgrade 2000.2.7
This is what i plan to do today to bring my system upto date, please let me know if i am missing something:
win-OS-Upgrade-K9.2000-4-2sr2.exe
SQL2K-ServicePack3.1-0-6.exe
ciscocm.4-1-3-sr2.exe
You'll need to install OS Upgrade 2000-4-2 before installing 2000-4-2sr2. Also, SQL2K SP4 is approved for CCM.
Hope this helps.
Brandon
117
