08-01-2002 04:33 AM - edited 03-12-2019 08:10 PM
When i choose inside region codec g729 on CCM then I see on gw (show call active voice brief ) codec type g729br8.
Is possible to change codec from ccm to gw to g729r8 and not to g729br8?
Martin
08-01-2002 10:33 AM
I think the phones will do g729br8. All versions of g729 are suppose to work with each other.
Thank you,
-Mckee
08-02-2002 12:18 AM
Codec g729br8 has in-build VAD. If I set no Vad on gw dial-peer, there is still
vad enabled during active call. On CM is Vad disabled.
That is why i wanted to change codec to g729r8.
Martin
08-02-2002 03:11 AM
you can do this with "voice class codec "
for example :
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
on the voip dial-peer you have to insert the:
voice class codec 1
perhabs also:
incoming-called number ..
hope this helps
regards
mehmet
08-02-2002 04:06 AM
Mehmet i have just tried it, but it does not work. I have configured it in the way
you described, but there is still codec g729br8 on gateway (show call active voice brie).
Thank you
Martin
