CCM -> GK -> IP to IP GW -> CME problem...
Hi all i got a CCM 4.1(3)sr3b with a Gatekeeper that allows me to reach my CME. Everithing is fine. If now i add an IP to IP Gw with the invia and outvia zone the call is connected but no voice path. If i use the IP-IP-Gw directly in the CCM it is working good...
IP-IP Gw is on the GK plateform but on another one it is the same. IOS 12.4(3e)
GK-IPIPGW config:
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
interface Loopback0
ip address 172.1.x.x.255.255.0
h323-gateway voip interface
h323-gateway voip id VGK ipaddr 172.1.100.1 1719
h323-gateway voip h323-id IPIPGW
h323-gateway voip bind srcaddr 172.1.100.1
sccp local FastEthernet0/0.105
sccp ccm A.105.B.1 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register xxx
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 4
associate application SCCP
dial-peer voice 2 voip
destination-pattern 3...
session target ras
dtmf-relay h245-alphanumeric
gateway
gatekeeper
zone local CCM-GK ipexpert.com 172.1.100.1
zone local VGK ipexpert.com
zone local BR2-GK ipexpert.com
zone local ATA ipexpert.com
zone prefix CCM-GK 1...
zone prefix ATA 4...
no use-proxy ATA default inbound-to terminal
no use-proxy ATA default outbound-from terminal
no shutdown
On the CCM only an H225 Trunk without MTP, Fast start no activated pointing to the GK ip address.
on the CME:
voice service voip
h323
sip
interface Loopback0
ip address 172.x.x.x.255.255.0
h323-gateway voip id BR2-GK ipaddr 172.1.100.1 1719
h323-gateway voip h323-id CME
h323-gateway voip bind srcaddr 172.1.102.1
dial-peer voice 10 voip
incoming called-number 3...
Any idee?
Eric
Re: CCM -> GK -> IP to IP GW -> CME problem...
Eric,
A few things seem to be missing. Is this your complete IPIPGw config ?
If VGK is the VIA zone your calls from CCM-GK to BR2-GK should go through the VIA zone and vice versa (if they have to call each other through the IPIPGw.
zone local VGK ipexpert.com 172.1.100.1
zone local CCM-GK ipexpert.com invia VGK outvia VGK
zone local BR2-GK ipexpert.com invia VGK outvia VGK
Also your dial-peers seem to be incomplete.
dial-peer voice 1 voip
codec g711ulaw
session target ras
codec g711ulaw
Dial-peers 1 and 2 will answer a call from CM and send it to CME. You will need two other dial-peers like this to send calls from CME to CM. I have set codec in this case to g711ulaw. If you are using g711 from CCM and g729 to CME, you will need to transcode the call.
Sankar
PS: please remember to rate posts!
I have my IP2IP gateway running?
How can I see active calls in my IP2IP GW?
show call active voice brief
Hi Sankar,
your post is right, there is no call from CME to CCM AND the IPIPGW is acting as a transcoder, call from CCM uses G711 and from IPIPGwto CME it is G729r8.
I found the solution, it was a parameter on the CCM that i forgot to uncheck: wait for far end h245 terminal capabilities.
To be honest, the configuration is a strange one because i am preparing for voice CCIE...
Thank you for your comments.
When you said your calls connected, but no audio, did you ever notice if one side was connected while the other side showed Ringout ?
It looks like it is connected on the CME side while the CCM still with ringback tone.
Eric,
Glad to know that you are expereiencing the same behaviour as i am when I test this out. So you are saying that if you uncheck the h245 far end cap. check under the trunk, your call is getting connected ?
YEP. Abolutely sure.
also preparing Voice CCIE?
I am managing the Video conferencing project but I am struggling to select the appropriate IOS for GK and also router. Please provide some suggestion.
1. Is 2620 is enough for GK? (I am going to use 8 X 256 Video calls through Tandberg gateway)
2. Please suggest the appropriate GK IOS?
Varatharajan
415
