Community Member
CCM Outbound LD calls register as 0
I currently have CCM 4.1(2)sr1, and have a long distance route pattern that, when used, registers 0 in the placed call directory. All other placed calls including local pstn calls are registered in the placed calls directory correctly.
What's odd is that the long distance placed calls used to register correctly. The last thing done to CCM that I can think of aside from add/remove/changes was installing CAR.
Any ideas?
1 REPLY
Community Member
Re: CCM Outbound LD calls register as 0
I ended up trying a new phone load, and it turned out that newer software fixed it.
Thanks.
117
