CCM Publisher private password phrase problem.
I'm getting the error that the password doesnt match. I know how to get into the CallManager Adimin Utility, but I dont know what box to check to reset the passwrod to the default one.
Also what is the default password.
Thank You
Bronze
Re: CCM Publisher private password phrase problem.
You need to check the box next to the Globe, and then do Options -> Set new password.
yes, i've done that but it just seems to sit there for a long time.
how long does it take to reset the passwords??
102
