Community Member
CCM running at max memory (1 gig)
Hi. Running CCM 4.1.3 sr1 and memory is maxed out. I noticed that logging into the CCM administration page takes a long time as well as navigating through the different areas of administration but don't know if it is related to the mem usage. Does anyone else have this symptom of high mem usage? If so, what is the fix? Add more memory? I figure on doing that, but would like to know if it is something else possibly. Below is an error indicating a low kernel stack.
Event Type: Warning
Event Source: SAVRT
Event Category: None
Event ID: 1005
Date: 8/24/2005
Time: 1:51:14 PM
User: N/A
Computer: CORPCCM01
Description:
Symantec AntiVirus Auto-Protect could not scan file C:\WINNT\System32\RDPDD.dll for viruses due to low kernel stack.
Data:
0000: 00 00 00 00 02 00 4c 00 ......L.
0008: 00 00 00 00 ed 03 07 80 ....í..€
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
Steve
1 ACCEPTED SOLUTION
Community Member
Re: CCM running at max memory (1 gig)
We got 4.13 CCM with 1.0G Memory with new server. We noticed that the memory run really low immediately.
We did whatever we can, for intance limit memory usage for SQL, but not much help. Finally, we upgraded to 2.0G. Everything is fine now.
Physical Memory Recommendations for Cisco CallManager Vers. 4.0
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_bulletin0900aecd80284099.html
Cisco recommends a minimum of 1 GB of physical memory on all servers running Cisco CallManager 4.0 and higher.
Publisher that is running Cisco CallManager service - 2 GB recommended
Community Member
176
