11-10-2003 06:40 AM - edited 03-13-2019 02:29 AM
I was wondering which Table in the CCM SQL database to change the External phone number mask.
It is set per phone and there has to be a way to change it in the SQL database instead of going into each phone or reimporting using BAT.
11-10-2003 06:44 AM
Warning if you do not already know if add the external mask it changes the DID display in the black display bar on the phones. I am running 3.22c and all Csico told me at TAC was that was by design and put in a feature request with your local contact.
Watch out for that.
11-10-2003 08:11 AM
Thanks for your quick response and you are correct in that it is the display on the phone.
I have already took out of the Route Patterns the Use External Phone Mask and have out it on the Gateway.
I would still like to knolw how to change that in the SQL database because I added an extra 6 in the mask that does not need to be there.
Thanks again
