Community Member
CCM version 3.3(2)spC CFwdAll problem with 2nd line
I am planning to upgrade to above mentioned version and when worked in Test Lab found Phones with 2nd line forwarded to 1st line Display Forwarded to message on phone continuosly which is misleading.
I have all phones (around 3000) with second line fwded to 1st line.
Though this is a bug listed in open caveats of 3.3(2)spC, Can anybody help with a work around.
Thanks and Regards
Bronze
Re: CCM version 3.3(2)spC CFwdAll problem with 2nd line
I am not sure of which caveat in this list you are talking about.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a00800a528f.html
If you know the bug id, then you can open the Release note of that bug using the bug tool kit and there the workaround might be documented.
Let me know the id of the bug that you are talking about.
Community Member
CSCdz03451
The phone displays Forwarded to message when CFA is enabled on the second line.
Workaround: None exists.
There is no workaround available, I wanted to know if anybody else has faced this problem and anyways to solve it
rgds
94
