01-09-2003 08:20 AM - edited 03-12-2019 10:12 PM
Is there a document showing how to configure the CCM and VLANs? There's no information in the IP Telephony Network Design Guide. I'm concerned about how to allow users web access to the CCM to configure their settings. If I put the CCM and IP Phones in separate VLANs, how do I allow users access? Second IP on the CCM and trunk the connection? Multi-home the CCM with a second IP? Put the Phone VLAN behind a PIX firewall interface?
Solved! Go to Solution.
01-09-2003 09:08 AM
There should be a layer 3 router that routes between the voice vlan and the data vlan.
-ben
01-09-2003 09:08 AM
-ben
01-09-2003 06:20 PM
Thanks.
I've got a 1750 I can use, so I'll use it as a one armed router. Only have 3524's so I don't have any switches with routing capabilities.
