CCM - voip gateway - PBX Integration
CCM ver3.3 is configured by using router-patterns and H.323 gateway configurations so that I can initiate a call from IP Phones through gateways (then ended at a PBX subscriber). However, the other way around does not work.
CCM: 10.81.50.2
IP Phone: 10.81.50.11
1st button on 7640: 3302
2nd button on 7640: 3304
Cisco 3640 H.323 gateway: 10.81.3.161
PBX is connected to Cisco 3640 via PRI trunk, HDV..
If it was initiated from IP Phones, call is established. Else if, call is droped if it is initiated from PBX.
Configurations are as follows:
IP Phone button 1: 3302
IP Phone button 2: 3304
CCM:
Route-pattern configs..
If 3XXX then forward to G/W:10.81.3.161 with a prefix 2
If XXXX then forward to G/W:10.81.3.161 with a prefix 2
Router 3640:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
interface Serial1/0:15
no ip address
no ip route-cache cef
no logging event link-status
no snmp trap link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn disconnect-cause 3
no cdp enable
voice-port 1/0:15
input gain -4
output attenuation 4
cptone TR
dial-peer voice 30 pots
destination-pattern 2....
direct-inward-dial
port 1/0:15
dial-peer voice 21 voip
destination-pattern 3302
voice-class codec 1
session target ipv4:10.81.50.2
ip precedence 5
Returned disc cause was: 3 "no route to destination".
Evenif I removed 3XXX and XXXX routes from the route-pattern list, same disc. cause returned from CCM to router.
Thanks for aid,
Onur
Re: CCM - voip gateway - PBX Integration
I take it your 3303 and 3304 DNs are a subrange of your PABX, so you are forwarding all non-CCM registered DNs out the gateway.
When you say cause code 3 in the PABX->CCM direction what was the contents of the setup message in the Debug H225 Q931? Looks like you have a translation problem on the digits or a partition/calling search space issue
Rory
I found the mistake. On the 3640 router, I have configure Loopback0 as H.323 interface for registering onto gatekeeper and initiating the voice call.
interface Loopback0
ip address 10.81.193.19 255.255.255.255
h323-gateway voip interface
h323-gateway voip id gk-uom ipaddr 10.81.3.160 1718
h323-gateway voip h323-id UOM_VOIP
h323-gateway voip bind srcaddr 10.81.193.19
interface Ethernet0/0
ip address 10.81.3.161 255.255.255.128
half-duplex
But on the CCM, I have defined route-pattern as through 10.81.3.161 instread of 10.81.193.19. When I changed the route-pattern as loopback 0 address of Cisco 3640, system became operational.
Onur
499
