Community Member
CCM - voip gateway - PBX Integration
CCM ver3.3 is configured by using router-patterns and H.323 gateway configurations so that I can initiate a call from IP Phones through gateways (then ended at a PBX subscriber). However, the other way around does not work.
IP Phone:
1st button on 7640: 3302
2nd button on 7640: 3304
Cisco 3640 H.323 gateway:
PBX is connected to Cisco 3640 via PRI trunk, HDV..
If it was initiated from IP Phones, call is established. Else if, call is droped if it is initiated from PBX.
Configurations are as follows:
IP Phone button 1: 3302
IP Phone button 2: 3304
Route-pattern configs..
If 3XXX then forward to G/W: with a prefix 2
If XXXX then forward to G/W: with a prefix 2
Router 3640:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
interface Serial1/0:15
no ip address
no ip route-cache cef
no logging event link-status
no snmp trap link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn disconnect-cause 3
no cdp enable
voice-port 1/0:15
input gain -4
output attenuation 4
cptone TR
dial-peer voice 30 pots
destination-pattern 2....
port 1/0:15
dial-peer voice 21 voip
destination-pattern 3302
voice-class codec 1
session target ipv4:
ip precedence 5
Returned disc cause was: 3 "no route to destination".
Evenif I removed 3XXX and XXXX routes from the route-pattern list, same disc. cause returned from CCM to router.
Thanks for aid,
Re: CCM - voip gateway - PBX Integration
Does the Calling Search Space assigned to the gateway include a partition with those 33XX extensions?
Community Member
I found the mistake. On the 3640 router, I have configure Loopback0 as H.323 interface for registering onto gatekeeper and initiating the voice call.
interface Loopback0
ip address
h323-gateway voip interface
h323-gateway voip id gk-uom ipaddr 1718
h323-gateway voip h323-id UOM_VOIP
h323-gateway voip bind srcaddr
interface Ethernet0/0
ip address
But on the CCM, I have defined route-pattern as through instread of When I changed the route-pattern as loopback 0 address of Cisco 3640, system became operational.
