CCM - voip gateway - PBX Integration
CCM ver3.3 is configured by using router-patterns and H.323 gateway configurations so that I can initiate a call from IP Phones through gateways (then ended at a PBX subscriber). However, the other way around does not work.
CCM: 10.81.50.2
IP Phone: 10.81.50.11
1st button on 7640: 3302
2nd button on 7640: 3304
Cisco 3640 H.323 gateway: 10.81.3.161
PBX is connected to Cisco 3640 via PRI trunk, HDV..
If it was initiated from IP Phones, call is established. Else if, call is droped if it is initiated from PBX.
Configurations are as follows:
IP Phone button 1: 3302
IP Phone button 2: 3304
CCM:
Route-pattern configs..
If 3XXX then forward to G/W:10.81.3.161 with a prefix 2
If XXXX then forward to G/W:10.81.3.161 with a prefix 2
Router 3640:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
interface Serial1/0:15
no ip address
no ip route-cache cef
no logging event link-status
no snmp trap link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn disconnect-cause 3
no cdp enable
voice-port 1/0:15
input gain -4
output attenuation 4
cptone TR
dial-peer voice 30 pots
destination-pattern 2....
direct-inward-dial
port 1/0:15
dial-peer voice 21 voip
destination-pattern 3302
voice-class codec 1
session target ipv4:10.81.50.2
ip precedence 5
Returned disc cause was: 3 "no route to destination".
Evenif I removed 3XXX and XXXX routes from the route-pattern list, same disc. cause returned from CCM to router.
Thanks for aid,
Onur
1 REPLY
Re: CCM - voip gateway - PBX Integration
This forum is for Unity, Cisco's Unified Messaging product. You might want to try the IP telephpny forum, if you don't get any answers here.
120
