Silver
CCM - VoIP Gateway
We have a CCM connected to a voip gateway.
At the gateway we use the command "csim start 67001" to call to a ip phone. With the "debug voip ccapi inout" we see:
Nov 26 08:27:04: csim: called number = 67001, loop count = 1 ping count = 0
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/ccAppInitialize: (name=CSIM , appHandle=0x64621F18)
Nov 26 08:27:04: csimSetupPeer peer type(2), destPat(67001), matched(2), target()
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest: (Inbound call = 0xFFFFFFFF, outbound peer =60007, dest=,
params=0x646211C0 mode=0, *callID=0x64621728, prog_ind = 0callingIE_present 0)
Nov 26 08:27:04: ccCallSetupRequest numbering_type 0x0
Nov 26 08:27:04: ccCallSetupRequest: calling number is:
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest: calling oct3a is:0x0
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest: after ccCheckClipClir - calling oct3a is:0x0
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest: dest pattern 67..., called 67001, digit_strip 0
Nov 26 08:27:04: callingNumber=, calledNumber=67001, redirectNumber= display_info= calling_oct3a=0
Nov 26 08:27:04: accountNumber=, finalDestFlag=0,
guid=0000.0000.0000.0000.0000.0000.0000.0000
Nov 26 08:27:04: peer_tag=60007
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
Nov 26 08:27:04: cisco-username=
Nov 26 08:27:04: ----- ccCallInfo IE subfields -----
Nov 26 08:27:04: cisco-ani=
Nov 26 08:27:04: cisco-anitype=0
Nov 26 08:27:04: cisco-aniplan=0
Nov 26 08:27:04: cisco-anipi=0
Nov 26 08:27:04: cisco-anisi=0
Nov 26 08:27:04: dest=67001
Nov 26 08:27:04: cisco-desttype=0
Nov 26 08:27:04: cisco-destplan=0
Nov 26 08:27:04: cisco-rdn=
Nov 26 08:27:04: cisco-rdntype=-1
Nov 26 08:27:04: cisco-rdnplan=-1
Nov 26 08:27:04: cisco-rdnpi=-1
Nov 26 08:27:04: cisco-rdnsi=-1
Nov 26 08:27:04: cisco-redirectreason=-1
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: (vdbPtr=0x63489D48, dest=,
callParams={called=67001,called_oct3=0x0, calling=,calling_oct3=0x0, calling_oct3a= 0x0,
calling_xlated=false, subscriber_type_str=, fdest=0, voice_peer_tag=60007},mode=0x0)
Nov 26 08:27:04: ccIFCallSetupRequestPrivate: src route label tgt route label tg_label_flag 0x0
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate: vdbPtr type = 1
dest=, callParams={called=67001, called_oct3 0x0, calling=,calling_oct3 0x0, calling_oct3a 0x0,
calling_xlated=false, fdest=0, voice_peer_tag=60007}, mode=0x0, xltrc=-5)
Nov 26 08:27:04: //2914/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: not incoming entry
Nov 26 08:27:04: //2914/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: entry's incoming FALSE.
Nov 26 08:27:04: //2914/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: is_incoming is FALSE
Nov 26 08:27:04: //2914/xxxxxxxxxxxx/CCAPI/ccCallSetContext: (callID=0xB62, context=0x6453EDF8)
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data: data_mode=0x10082
Nov 26 08:27:04: //2914/xxxxxxxxxxxx/CCAPI/cc_api_get_ic_leg_obtained_numbers: callID=0xB62
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: remote IP is 0.0.0.0
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: hwidb is FastEthernet0/0
Nov 26 08:27:04: //-1/xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: added for entry: 2, voip: 2, mmoip: 0
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnected: (vdbPtr=0x63489D48, callID=0xB62, cause=0x31)
Nov 26 08:27:06: csim_do_test: cid(2914), ev(11), disp(0)
Nov 26 08:27:06: csimTraceSct: cid(2914),st(0),oldst(0)
Nov 26 08:27:06: csim err csimDisconnected recvd DISC cid(2914)
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: (callID=0xB62, cause=0x31 tag=0x0)
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: calling accounting start for callID=2914 leg_type=0
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: existing_cause = 0x31, new_cause = 0x31
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccCallDisconnect: using the existing_cause 0x31
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/cc_api_get_transfer_info: (callID=0xB62)
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[2914], tagID[30], instID[-1]
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccTDPvtProfileTableObjectAccessManager: No profileTable set for callID[2914]
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[30] of callID[2914]
Nov 26 08:27:06: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif: expect factor = 0
Nov 26 08:27:06: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: the remote IP is 0.0.0.0
Nov 26 08:27:06: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: hwidb is FastEthernet0/0
Nov 26 08:27:06: //-1/xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: reduce callnum of entry: 1, voip: 1, mmoip: 0
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done: (vdbPtr=0x63489D48, callID=0xB62, disp=0, tag=0x0)
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByRef: No tdObject found in profileTable for tagID[6] of callID[2914]
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/cc_delete_call_entry: not incoming entry
kisin#
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/cc_delete_call_entry: entry's incoming FALSE.
Nov 26 08:27:06: //2914/xxxxxxxxxxxx/CCAPI/cc_delete_call_entry: is_incoming is FALSE
Nov 26 08:27:06: csim_do_test: cid(2914), ev(12), disp(0)
Nov 26 08:27:06: csimTraceSct: cid(2914),st(2),oldst(0)
Nov 26 08:27:06: csim: loop = 1, failed = 1
Nov 26 08:27:06: csim: call attempted = 1, setup failed = 1, tone failed = 0
The outbound peer is OK, but we can see that the remote IP address is 0.0.0.0, it should be the call manager address.
Any idea?
Re: CCM - VoIP Gateway
is this still a problem?
Have you got the session target in the VoIP dial-peer correct? can you paste your voip dial-peers?
Silver
Hello, the dial-peers are correct:
dial-peer voice 60007 voip
destination-pattern 67...
voice-class codec 99
session target ipv4:158.42.250.141
dtmf-relay cisco-rtp h245-alphanumeric
no vad
149
