CCM4.xx Question
Will CCM4.xx run on non Cisco hardware ??.
i.e Can I install it on an HP DL380G server ??
or
Can i take a disk out of the MC7800 and install into the DL380 ??
Basically my company have two offices and want a way to run redundant publishers so that they can maintain extension mobility .
But on the hardware they currently have in place.
Please help !!
Scott.
1 REPLY
Hall of Fame Super Silver
Re: CCM4.xx Question
As long as the DL380 is not an old one it will work, make sure you have enough RAM. As to the disks as long as they meet the capacity requirement you'll be fine. Check out this link:
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure09186a0080107d79.html
Also, not sure what you mean by running 2 Publishers as that is impossible in one cluster. You can build EM redundncy with subscribers as well.
HTH, please rate all posts!
Chris
99
