09-14-2008 09:43 PM - edited 03-13-2019 05:39 PM
Hello
I have ccm 5 and outside branch works in the g729 codec i need configure transcoding but then i try configure transcoding like in the documnetation
i see only ccm 4.1
scc ccm 192.168.22.20 identifier 1 version but my ver sion is 5.1
so how configure transcoding for ccm 5
09-15-2008 05:15 AM
follow this link config
just make sure u have put the right ccm verion
and setting on both router and ccm similer if not identical :)
good luck
if helpful Rate
09-15-2008 05:51 AM
hello thank you for your response but in the voice gateway haven't ccm5 version
only 4.1
09-15-2008 07:38 AM
Hi, Upgrade your GW IOS to 12.4(15)T7
09-15-2008 09:43 AM
if you don't have it simply try dropping the version command, many times that does the trick without doing an IOS upgrade
java
if this helps, please rate
10-08-2008 05:06 AM
i manage to use "version 4.1" with cucm 6.1
