Community Member
CCME and gatekeper integration
I have branch router 1760 with CCME and trying to register with central site VOIP gatekeeper router 7200.
Under branch router config I am configuring following under each local POTS dial peer to avoid these register with gatekeeper:
dial-peer voice 150 pots
destination-pattern 8#T
port 0/1/0
forward-digits 7
no register e164
But for the ephone configs which appear as virtual dial-peers there is no way of appliying "no register e164" command to avoid these local ip-phone directory numbers ( actually these are branch extension mumbers) getting registered with central gatekeeper.
Is there any workaround for this issue ?
1 REPLY
Silver
Re: CCME and gatekeper integration
You can set this up in the ephone-dn using the no-reg keyword
Ex:
ephone-dn 10
number 5000 secondary 6000 no-reg [both|primary]
Depending on your setup, you can either not register both numbers or just the primary.
Anup
111
