ccme and problem with outgoing call
hello,
i use a cisco 2821 router with ccme and two double bri interfaces.the router is between a PBX and the two telecom NTBAs of the german telecom.(Anlagenanschluss)
incomming call are ok but not the outgoing calls.
look at following config and debug file
any idea ?
Silver
Re: ccme and problem with outgoing call
called number is being expanded to a full E.164 number. This won't match your sip dial-peer to go to voice mail. We can use translation paterns so that we can manipulate the number and get it to go to CUE.
voice translation-rule 1
rule 1 /^962810\(.*\)/ /\1/
voice translation-profile to_cue
translate called 1
dial-peer voice xxx voip
translation-profile outgoing to_cue
destination-pattern xxxxxxxx
session protocol sipv2
session target ipv4:x.x.x.x
dtmf-relay sip-notify
codec g711ulaw
no vad
Please add the above configuration to your CME (this dial-peer is extra to the one you already have there for voice-mail... you will need both) and try it.
The solutions was to upgrade the IOS because there was a bug.
114
