CCME ATA and Fax
I've got a problem with CCME with ATA and Faxes.
1 REPLY
Re: CCME ATA and Fax
Sorry about the previous post. Some small problem with posting.
CCME version 123-8.T8.
ATA v3.1.2 atah323
Fax 3 differents tested with 9600 bps
I first tried with passthrough but in this case the end of 80 % of the faxes was unreadable. So I moved to Fax mode, in this case on all the faxes there is small part missing, about 1 millimeter of half milimeter on the height, from time to time. This make the fax unreadable on this specific line.
Is it a normal situation ? I heard about quality problem with CCME + ATA + Fax.
Is there a workaround ?
Charles
134
