Community Member
CCME & Auto Attendant
I am trying to test the functionality of the auto attendant with CCME on a 3640. When I call into the FXO port I get prompted correctly by the AA but when I enter the destination number , which I can see being collected via debug, nothing happens. Makes no difference if I wait for a time out or use the # just dead air.
Any ideas.
IOS (tm) 3600 Software (C3640-IK9O3S-M), Version 12.2(15)ZJ3, EARLY DEPLOYMENT R
TAC Support:
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 25-Sep-03 22:53 by eaarmas
Image text-base: 0x60008950, data-base: 0x61E9C000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
ROM: 3600 Software (C3640-IK9O3S-M), Version 12.2(15)ZJ3, EARLY DEPLOYMENT RELEA
ok-okc-ccmetest uptime is 1 day, 5 hours, 4 minutes
System restarted at 07:42:43 CST Wed Jan 14 2004
System image file is "flash:c3640-ik9o3s-mz.122-15.ZJ3"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco 3640 (R4700) processor (revision 0x00) with 126976K/4096K bytes of memory.
Processor board ID 10579049
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
4 Ethernet/IEEE 802.3 interface(s)
2 Voice FXO interface(s)
2 Voice FXS interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Configuration register is 0x3922
tftp-server flash:P00303020214.bin
call application voice autoatt flash:its-CISCO.
call application voice autoatt aa-pilot 5555
call application voice autoatt oper 5001
call application voice autoatt en 0
call application voice autoatt language 1 en
call application voice autoatt set-location en 0 flash:
call rsvp-sync
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
mgcp profile default
dial-peer cor custom
dial-peer voice 5000 pots
destination-pattern 5000
port 0/0/0
dial-peer voice 5555 pots
application autoatt
incoming called-number 5555
port 0/1/0
load 7960-7940 P00303020214
max-ephones 24
max-dn 48
ip source-address port 2000
create cnf-files version-stamp 7960 Jan 12 2004 16:01:33
max-conferences 4
ephone-dn 1 dual-line
number 5001
label Line1
name Test Phone
ephone 1
mac-address 0010.A4B4.71BA
type 7960
button 1:1
System flash directory:
File Length Name/status
1 20736768 c3640-ik9o3s-mz.122-15.ZJ3
2 496521
3 369950 P00303020214.bin
12 3743 admin_user.html
13 6315 ephone_admin.html
14 3603 normal_user.html
15 2418 telephony_service.html
16 10230 xml-test.html
17 16948 dom.js
18 560138 admin_user.js
19 77566 normal_user.js
20 2515 xml.template
21 301298 ata18x-v2-16-ms-030327b.zup
22 42484
23 26376
24 14352
25 19512
26 17167
27 17486
28 6876 its-CISCO.
[22745404 bytes used, 10284740 available, 33030144 total]
sh call app voice summ
name description
session Basic app to do DID, or supply dialtone.
fax_hop_on Script to talk to a fax redialer
clid_authen Authenticate with (ani, dnis)
clid_authen_collect Authenticate with (ani, dnis), collect if that fails
clid_authen_npw Authenticate with (ani, NULL)
clid_authen_col_npw Authenticate with (ani, NULL), collect if that fails
clid_col_npw_3 Authenticate with (ani, NULL), and 3 tries collecting
clid_col_npw_npw Authenticate with (ani, NULL) and 3 tries without pw
Default Default system session application 2.0
CTAPP Call Treatment Action Application
DEFAULT.C.OLD Obsolete system session application
lib_off_app Libretto Offramp
TCL Script Version 2.0 supported.
Call Treatment Action Application - Version 1.0.
TCL Script Version 1.1 supported.
Voice Browser Version 2.0 for VoiceXML 1.0 & 2.0 supported.
Re: CCME & Auto Attendant
Try giving the command "forward-digits all " under the dial peer configuration.
More details on the command can be found at :
Community Member
Hey there,
I've got the exact same problem.
So don't bang your head against the wall too much!!
I'm trying the exact same thing on a 2651XM.
Hopefully someone knows what tweaks to make in the script file.
Community Member
I am also having similar problems with the auto attendant. I am running mine on a 1760-v.
Can anyone post a working complete config?
Thanks - Kevin
Community Member
For what is is worth I went back to 12.2.15.t10 from 12.2.15.zj3 on the IOS and to cme- from cme-3.0.3 and it starting working. I suspect there is some problem with the AA script but I wasn’t ready to spend the time to try and decipher it’s inter workings.
Community Member
Can you send me a copy of the script you are using and the router config. I would like the team to investigate why this does not work in ZJ3.
Community Member
The default AA script available on CCO designed for the 12.4T train doesn't work with 12.4(3)T2 (on my Cisco 2651).
No changes or modifications to the script. Just the one included with the the file on CCO.
Community Member
Reply from engineering:
I've confirmed CSCed02484 is NOT in 4T. We need to commit it. However,there is a workaround. It should work if they configure direct-inward-dial on the POTS dialpeer.
Most likely you will see this bug fix in 4T4 due out end of March.
Community Member
To confirm your problem is CSCed02484 (handoff fails from TCL script to enhanced session app), enable "debug voip ivr error." A "Cannot ACK this leg" error appears when you use the Auto-Attendant script.
A potential workaround is to configure your POTS dial-peer to have direct-inward-dial as shown in the following example:
dial-peer voice 1 pots
application aa
incoming called-number 12345
port 0:D
Community Member
I have the same problem.
I used the workaround but when the incoming
call gets transfered to the operator ip phone, operator cannot transfer call anymore.
TCL Script goes back and plays welcome message.
Community Member
I had the same problem last week on a 1760-v-ccme. We had to put direct-inward-dial on the dial peer with the aa application and we had to upgrade the ios to 12.3.4T2 We had just T.
Try upgrading the image and using the Direct inward dial command
dial-peer voice 100 pots
application aa-imageline
destination-pattern 1000
progress_ind setup enable 3
port 0/0
