Community Member
CCME call a group of ephones
Maybe someone has a solution to such a task. I have a group of phones, which are 7912 and above, and I want to deploy them into one group, which will be available under a single ephone-dn(ex. 333). And if 333 is called I want all of ephones located under that number to ring simultaneously, until one of them is answered. Then call sould be routed to the answered phone. Is there a solution to do something like that, without using the Gpickup function?
Thanks for your help in advance
Best regards
Michal Podoski
1 REPLY
Hall of Fame Super Silver
Re: CCME call a group of ephones
Well there is several ways of doing this.
1. use shared line, apply the same ephone-dn to all phones
2. use Overlay DN, apply the overlay DN to all phones
3. Use ephone-hunt and list all the phones in the hunt lists
Niezapomnij ocenic tego postu ;-)
Chris
122
