Community Member
CCME - callout extension number not displayed
i´ve got 3825 incl. CCME3.3 and E1. If i called out, my extensions (29) 8564-111 will displayed on the other site to 85640. Here an Issue:
dial-peer voice 1 pots
description ** E1 PRI pots dial-peer **
preference 7
destination-pattern 9911
port 0/1/0:15
forward-digits all
dial-peer voice 2 pots
destination-pattern 0T
port 0/1/0:15
dial-peer voice 3 pots
incoming called-number .
direct-inward-dial
port 0/1/0:15
dialplan-pattern 1 8564... extension-length 4 extension-pattern 4...
Whats wrong
thanks
Ronny
Super Bronze
Re: CCME - callout extension number not displayed
Hi Ronny
I'm sure we can give you a fix for this, I'm just not completely clear what you're trying to do...
Are you saying that phones outside your site see the wrong calling number?
If so, what are your extension numbers, and what SHOULD the calling numbers show up as?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Hi Aaron,
the phones outside my site see xxx85640.
I have extensions xxx85640-00 - xxx85640-99 and the other Sites should see xxx8564000.
The extensions are not sent to the telecom provider.
In my comprehension, the CCME should sent the extensions also.
The following lines
forward-digits all
diplay not the extensions.
thanks
Ronny
Community Member
"the phones outside my site see xxx85640", is this the main number or is the main number xxx8564000 ?
try running a debug isdn q931, there the calling number (and the called number) should be displayet, and you will se what "calling number" you are sending to the telecom provider.
If you are sending a number NOT in the numberseries you have subscribed the telecom provider will remove this and show the main number, just a thought...
/runar
Super Bronze
You have two digit extensions internally?
i.e.
01
02
98
99
And you only want your main office number to show?
If you can confirm this I'll suggest some config...
Aaron
Community Member
Hi Aaron,
i have 4 digits internally.
4001
4002
4099
The Main Number is 85640 and this will displayed on external site.
My DID is 8564004.
I attached the isdn q931 debug with calling number 8564004 and the shorted config.
ciao
Ronny
Super Bronze
Hi Ronny
First I'd do away with the telephony-service dialplan-pattern command - i prefer to use translation patterns.
Then create the translations (I've set this to change any extensions starting with 40, to translate to the 85640 number you mentioned - if I've misunderstood you can put whatever number you want there that your telco will permit).
voice translation-rule 1
rule 1 /^40../ /85640/
voice translation-profile OutboundCLI
translate calling 1
And apply this to your outbound dial-peers:
dial-peer voice 1
translation-profile outgoing OutboundCLI
dial-peer voice 2
Since you haven't got the dial-plan command any more, you might need to translate the incoming called numbers from the PSTN to your extension numbers... for example if telco sends 8564004 and extension is 4004, this rule would translate this and any others in that number range to your internal extensions:
voice translation-rule 2
rule 1 /^85640../ /40/
voice translation-profile InboundDDI
translate called 2
dial-peer voice 3
translation-profile outgoing InboundDDI
Obviously you may need to change this translation as well.
So in Germany you have a short main office number, with DDIs being the same with extra digits? That seems very strange to us UK folk...
Aaron
Hope this helps - please rate my replies if they do!
171
