CCME CLID on transferred calls
I have CCME with a PRI connection to the PSTN. Calls to the receptionist from the PSTN show the PSTN CLID, but when the receptionist transfers the calls to an internal extension, the extension displays the receptionist's CLID and not the originating CLID of the PSTN caller.
Can the CCME be set up to display the orignal PSTN CLID instead of the receptionist CLID when she transfers calls?
Hall of Fame Super Red
Re: CCME CLID on transferred calls
Hi Ian,
Is the receptioist using full-consult type transfer? I have read that if you change the receptionist ephone to use transfer mode blind or local-consult the CLID will show the way you want it to.
transfer-system {blind | full-blind | full-consult | local-consult}
•blind—Calls are transferred without consultation with a single phone line using the Cisco-proprietary method.
•full-blind—Calls are transferred without consultation using H.450.2 standard methods.
•full-consult—Calls are transferred with consultation using H.450.2 standard methods and a second phone line if available. The calls fall back to full-blind if the second line is unavailable.
•local-consult—Calls are transferred with local consultation using a second phone line if available. The calls fall back to blind for nonlocal consultation or nonlocal transfer target.
Hope this helps!
Rob
Please remember to rate helpful posts........
I think what you're looking to do is the following under the ephone-dn of the receptionist:
ephone-dn xxx
caller-id passthrough
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00805e91b1.html#wp1007278
125
